Originally Posted by
5FDP
The MAF is set to fail, so those DTC's are normal. Revert back to stock settings and those MAF codes will go away.
You need to purchase a wideband o2 sensor so you can correct the VVE and MAF curve to get fueling under control.
Are you trying to run E85?
I see that your alcohol % is up around 65%. Just note that the virtual sensor uses the fuel trims to figure out the correct stoich, it's not very accurate and most will suggest you wire in a real sensor if you want to run E85 all the time.
