1st Post Here > 2011 Corvette cammed LS3 > Adaptive Spark Control question
This is my first post here on the HP Tuners forum.
I have a supercharged (Magnuson Heartbeat PD) 2011 Corvette GS (LS3 / A6). I just purchased the MPVI-2 tuner for tweeking the dyno tune that the car already has had installed in it.
The reason I would like to tweek the tune is because since installing an aftermarket cam (220*/234* . .585"/.585" . 118* LSA . -9* Overlap) the car has a side to side shake in gear or in park while cold idling. Once the engine warms up, the car idles pretty smooth.
Below is a post made by another member concerning the adjustment of the 'Idle Adaptive Spark Control' overspeed and underspeed tables to help smooth out the idle.
Quote:
Originally Posted by
sgod1100
.... if you want to try and calm the shake down go to the "spark" tab, then under "Idle Adaptive Spark Control" multiply both the over and underspeed tables by .5 (basically cutting them in half).
Well, the problem I have is that my new MPVI-2 software does not have the "Idle Adaptive Spark Control" option ... Was that something only available with the older MPVI-1 software maybe ?
