I don't have use VID. I've loaded a few different tunes and none have it. Unless I'm looking in the wrong spot? Speedometer section correct?
Got it. had to turn on advance view.
Enable Tire and Enable Gear
if setting N/V then 40.3 isn't going to do anything.....try 43 instead.
thanks for this
Is there a way to correct the reading off the front ABS sensor if larger wheels are used on 2015 GT?
yes
Forgive me for bringing back an old thread, but has anyone successfully changed the N/v Min Learned value? I notice other years of my year truck have a min value of 30 while the most up to date calibration on my truck has a min value of 50. Which is higher than the stock Base N/V value of 40.
