New to Ford tuning BA XR6T
Hi all.
I am new to these forums and I would like a little bit of input on tuning a BA XR6 turbo manual.
This will be the first Ford I have tuned and need to just confirm what tables I will be adjusting. I have had years experience tuning forced motors with tunerpro but only had experience with HPtuners tuning LS1s and LS2s.
the vehicle is 2002 manual with 15psi wastegate actuator, bosch 440cc injectors, plazman intercooler setup and that's it. I know it is right on its limits maybe ie. valve springs, possibly injectors.
The tables I have been studying for my main fueling are airflow/general/speed destiny -map at zero (MAP at zero Airmass IMRC open), and/or fuel/open loop -base map. are these the main maps to modify?
I also assume the values for over boost and under boost will also need a touch up from stock file.
any input would be greatly appreciated guys.
