hesitant to touch desired throttle area
Upgraded from a 78mm to 90mm DBW throttle body, since the throttle body is so much larger, i find myself using areas of the pedal that I never was in before, very low pedal position %'s. These areas seem to be very very unresponsive, you really have to get above 1/8th to 1/4 throttle before you start getting any sort of resolution in the DBW. I was looking at the desired throttle areas and that seems to back up what im feeling, but my question is, since HPT puts these huge warnings on modifying these tables, is it risky to attempt this on an E67 ecu running an LS3 throttle conversion? Does this write to the ECU or the TAC module since it claims it can brick either? What is an acceptable change? Im posting below what id like to change to vs what is stock.
http://www.hostthenpost.org/uploads/...7dc582faa5.png
http://www.hostthenpost.org/uploads/...61d1561084.png
