3 Attachment(s)
Help with injector swap deatschwerks 44lbs in lq4 running lean
Hi guys I have a stock lq4 and have installed new deatschwerks 44lb injectors (35U-01-0044-8), I have adjusted the Flow rate, limits, offset and pulse corrections, however its running super lean and i have verified it with an inovate wide band.
2006 2500HD 6.0 4L80E 4x4 100,000 miles
Truck had a random misfire when I got it, it was also running lean, had exhaust leaks, was down on fuel pressure and was neglected, so instead of diagnosing it I just replaced everything I thought was worth replacing
I have replaced the following sensors etc for new ones
Delphi
O2 sensors x4
Crank Sensor
Cam Sensor
Map Sensor
Knock Sensors
Airflow Meter
Other new parts
Felpro Intake mainfold Gasket
AC Delco PCV
Delphi Leads
NGK Iridium Plugs
AC Delco Exhaust mainifold gaskets
Delphi Fuel pump
I have enabled PE and changed torque limits
I have verified the fuel pressure, the o2 sensors are accurate, done a crank relearn, cleaned the throttle body
I think i may have overlooked or entered the injector data wrong. any help would be appreciated
