2 Attachment(s)
6L80 S-Mode 4,5,6 Shift Point Issue
Hello,
I have a 2013 Corvette LS3 with a 6L80 and I have a weird shift point issue that I can't figure out.
In D-Mode, everything works exactly as expected based on the tune. TUTD works just fine.
In S-Mode, the everything works fine in 1st thru 3rd. When I reach my 3->4 shift point, the car shifts to 5th and then quickly to 6th instead, even though I haven't reached those shift points yet... I have looked through the tune and searched a lot and cannot find any answers.
I have tried a write entire [and burned 2 credits along the way] with a stock tune from the HPT repository (same OS, same year, same car, etc.) and then added my calibration differences to that with no effect.
This is really annoying as I can basically only use S mode for WOT (works perfectly) and TUTD (also perfect).
The car has H/C/I/E/meth/etc. I'm running a ProTorque 3200+ stall converter with triple-disc carbon clutch. Quite happy with the tune in general except for this bug.
Attached are the tune and log of this phenomenon. As you can see, Pattern A and Pattern B both have identical parameters to the Normal pattern (shift scheduling and TCC scheduling).
Any help is greatly appreciated!
Attachment 95096
Attachment 95097
The issue can be seen around 1m 41s into the log. I then switch to D-Mode for the majority of the log, showing that the issue is not present there (e.g. 2m 35s). The issue can be seen in S-Mode again at 11m 40s, where the trans jumps straight from 3rd to 6th.
