Originally Posted by
Harlech
The manifold isn't the issue, even the L83 isn't your restriction on air flow, your intake is first and foremost. The gains you are going to see on a NA application aren't going to be HP/TQ gains so much as throttle response gains by being able to run the larger TB. Look at the MAF curves between the LT1 and L86, the LT1 breaths better because it is a better intake design and a better exhaust from the factory, not a better intake manifold. There is a reason the Corvette guys are aren't making as much HP on an CAI as the truck guys are. You might pick up a couple HP on the top end with the LT1 manifold, but you are going to lose some torque in the midrange compared to the L86. Pick your poison.
