Originally Posted by
GHuggins
Didn't look at the trans settings, but the only thing I saw on the engine side that needs attention - and you'll find out once you start running ethanol and fueling starts going astray - is your E multiplier for the MAF side of the fueling is going in the wrong direction. I know this is how the OE sets them up as well, but I've never had it keep fueling right. You really need to copy the multiplier from the SD side and put it into the MAFs multiplier under the main fuel tab. It really needs to be dialed in which requires running it at the different E levels and correcting it to keep fueling the same for all E percentages.
Timing - if it's working for you then OK, but looks a bit high once you start adding in the PE settings. Even for gas...
