Car was ruuning fine with no problems, managed to flash it 3 times on the dyno, then all oof a sudden the vehicle would not switch on.
Security light on and flashing.
Disabled PATs in flash and still no start.
Any ideas HP Tuners?
if you just turned off pats in hp tuners then take ids and go to pats and click reconfigure settings there. it just flew the synchronization between ipc and pcm
Turning off pats in year 10 is not so simple. and unchecking hp doesn’t help, I just came across this
