1 Attachment(s)
ODB2 Throttle Actuator vs Throttle Position
Hello,
Trying to sort out the throttle gauge feature. My OBD2 (Kiwi 3) shows options to monitor Throttle Actuator% (ID 4C) and Throttle Position% (ID 11).
The attached image file contains an output scan.
Attachment 62974
ID 11 reads 11.76%
ID 4C reads 1.96%
Vehicle is at idle (694.75 rpm).
Any thoughts on the following:
1) Why is ID 11 reading 11.76% with vehicle at idle and no throttle is applied by the driver?
2) ID 4C @ 1.96%, same here.
3) Presumably I should use ID 4C instead of 11 to represent throttle position in my case?
4) What does Absolute Engine Load (ID 43) represent?
