Need advice for 3800 series 2 turbo
Ive been researching and reading up on hp tuners for about a year now. Even when i didnt own hp tuners, i downloaded the software and some 3800 tunes, to look at while reading and watching videos. Trying to get the hang of it. So that way when i finally got to install the PnP heads with #136 springs, bigger Intake and Exhaust valves, Bigger Cam ( ZZP'S stg 4 turbo cam ), ls7 lifters, on top of the turbo kit i bought from Cartuning ( which came with a tuned pcm, ls1 MAF, and lucas 42.5 lbs injectors ). So i could just get to tuning it.
But it hasnt been quite that easy. I cant find any tutorials for the 3800 on setting up the idle. The ones i did find are either non existent now ( write up on turbov6 ) , only start the write up if your car can already idle, or if it is about idling then there are tabs and tables i dont have on my pcm. And i dont want to skip over things or make the wrong adjustments and mess up my car.
So from the research ive done you want to adjust the base target idle ( or in my case its just called BASE ) in the idle tab. Then goto the idle airflow and adjust it. But now this is where my problem starts cause i dont have that table in my idle tab. So i dont know what i have to adjust next for the idle air flow. If yall could give me some knowledge, I would greatly appreciate the help.
