Mass air code P0102-00 came on after mins of idle time
Also have codes P0650-00 and P10E1-00.
Thoughts?
P0102, MAF low output makes sense for the 4" tube. If you just follow the write-ups for MAF tuning you will probably resolve that and have a much better running engine.
P0650 just means that you don't have a check engine light wired up. You can turn that off in the tune under diagnostics (set to no error reported).
P10E1 I can check tomorrow
You're correct. If the VVT is set to none, that means it has been deactivated.
ok here are some logs with the VVT on and a new maf curve suggested by a co-worker it starts cold or warm excellent now, looks like fuel trims are off tho thoughts? thanks again for the helpAttachment 96677Attachment 96678Attachment 96679Attachment 96680
The logs show that this advice...is still needed
Replied to your PM!! Larger houseing for the MAF lowers the Hz range so rescaling the MAF sensor is necessary!
Zero out VVT entirely on a stock cam cost you power
