How or can I data log the tcm, shift points, pressures etc on Ford 5r110. Trying to tune trans to work with Cummins.
IN the scanner hit the vehicle icon to connect, once connected but not logging open the vehicle drop down and click on repoll for supported parameters and then look for your trans PIDs and see if that works.
Thank you I will try that and see if it works.
Still no luck after re polling. Only thing itll bring up regarding transmission is control module voltage
Ok, had to update software to the new Beta version. Now its reading and I'm finding the missing pids. Now have to figure out what I need to monitor in order to fix trans tuning.
[QUOTE=guy-ffc;622447]did you get this working?[/QUOT
No, I gave up on trying to get it to work. Im using an sct x4 which has all he pids for trans data log.
