Need help/advice with P/N and unstable Idle...
I am in the middle of trying to tune this P59 DBW FlexFuel ECM for my rock crawler. I don't have a dyno so I'm tuning it by driving it trying to hit all, or most, of the conditions. My problem is, everytimne I come to a stop it will die. It will start right back up and idle good, as soon as you come to the next stop, or blip the throttle while still it will die.
I have the idle set to about 785. I don't have any signal going to the ECM that tells it it's in P/N or in gear. The trans is a 400T.
I'm thinking I need to rig something up to let the ECU know it's either in P/N or in gear to fix this but I'm not sure.
If I need this, how does the P/N function work with this ECM? I think I understand that it uses one wire for this function, and uses a ground signal, but is the wire grounded in P/N or in gear?
Can some of you knowledgeable folks on here help a guy out? Thanks so much. Can post the tune if I need too this evening.
