Hey guys I've been chasing down what I thought was transients but turns out it's the delay between the tps map and o2. How do I filter in order to line these up on the charts/ graph?:confused:
This should be a very easy question to answer for one of you pros. How do I filter in order to line up the tps map and 02? Come on man!
Post your Tune and logs as well as a little info on your vehicle.
Then you will probably get some responses. I'm not the guy, but the Pros usually blow right on by these threads without at lease a log.
I'm wondering if you are talking about delay in o2 feed back? If so I believe that is tuned for with integral delay and o2 switch points not a filter within the graph.
Yeah thanks for responding, I'm asking about the special functions, the filters. What I need is to delay the tps and map to match up to the o2 on the scanner/ graph. I've been screwing with transients and finally figured out that I'm chasing the delay between the tps map and o2. There's got to be a way to filter it.
Ok I'll make it easier, what does the shift filter do?
Wish I knew
Have you tried posting the question in the Scanner section? Maybe title the question Special Functions Filter
Hey man I appreciate you, but I think next time i will be using Holley.
