3 Attachment(s)
LC-1 Wideband---help with set up in Scanner
I need help. I cannot get my LC-1 wideband to work with my scanner, Version 4.4.4. I am scanning the EGR volts, Air Fuel Ratio Commanded, and I have watched every You Tube video on how to set up a wideband with HPTuners 3.X software. I set it up in the Graph section. I know its working, the blue box moves around on the graph, but there are NO NUMBERS in the box.
I am using Engine Speed for the top Column Axis, and Manifold Absolute Pressure (Sensor) for the Row Axis. Is that CORRECT???
My car is set up for a 150 shot of Nitrous, but I can't (will not) use it until my wideband is working.
Can someone look at my previous post--"Laptop Crashed----Need Help with Scanner" and help me get my wideband working??
I have attached UPDATED Layouts, Channels, and a short scan.
