4l60e Torque Management Recovery Rate
Hi All,
I was wondering how to change the recovery rate for torque management of the transmission.
I have a 4l60e that is very well built. I build transmissions and have multiple out there at 450+ hp...this is the same build for my personal car and I'm playing with the tune.
I am having an issue where the 2-3 shift holds torque management forever it feels like. I can attach a log if need be, but there is timing pulled when the shift is commanded, and it stays pulled for over 2 seconds, then it is "given back" making the car feel very sluggish on the 2-3 because it is down on power. The shift itself is performed no problem, and the trans is doing great. If I disable 2-3 shift torque management, the shift is just as crisp as before, but the engine clearly has full power and pulls much harder.
Ideally, I'd like to be able to keep the torque management in and only have it pull timing for a fraction of a second.
I can find parameters for knock retard ramp rates...but not for torque management retard rates.
Can someone help with this please?!
