03 Cummins 24v 5.9 SWAP into 08 Ford F350 Frankenstein!!
Hi All,
We are having issues turning off the skim (so we believe ) on our 08 ford f350 with an 03 cummins 24v 5.9 & ecm (this ecm came with SKIM). We turned off the skim using HPT and had our tuner zap the skim code out as well so it doesnt show up in the scanner. The truck wont start, it just cranks, probably not allowing the injectors to fire. I contacted HP support and they said you may need a dodge wiTech device (dealer only) but when i called the dealer they said that it only works for 07 and up and they dont have anything to support that. :confused:
Has anyone done this swap before and can anyone lend some help? thanks in advance.:o
