3 Attachment(s)
6L80E Shifting Early Regardless of Adjustments
Cadillac XLR-V E67 T43
I've got an issue with my shifting. Regardless of what I set shift speed and/or MPH, it always seems to shift early. I've even gone to the extreme and added 15mph to the shift speeds, nothing! Almost always, the 1-2 shift happens after 6400rpm. But 2-3 happens around 5800rpm and 3-4 around 5100rpm. Even WOT downshifts, it doesn't seem to want to drop down to the correct gear. Cruising at 45, and go WOT, it "should" go into second, but usually just stick to third. I'd like to see each gear WOT shift around 6600rpm.
28" Tall tires (front and rear), 3.42:1 Rear gear, Speedo is dead nuts. I've tried in Pattern A, Pattern B, TUTD (letting the ECU take over shifts) all three patterns act the same. I've tried with Traction ON, OFF, Both TC and ST off, Performance mode. Even pulled ABS Fuse, same behavior. Ive changed "Speedometer Source" From calibrated to gmlan, no difference. I have matched ALL of the tables to the same WOT Shift speed. Same result every time. I have flashed with Beta and NON-Beta, same results
What am I missing here?
Attachment 93536
Attachment 93537
Attachment 93538
