Please Email Support.
OK Thanks
will this software be able to tune Mercedes e55 amg trans missions. Egs52?
Can we change tire size and gear ratios yet?
Yes you can on most supported Dodge vehicles.
Gear/Tire Adjustment - 2.25 Scanner
Great! thanks
I am working with support team now to resolve issue. They are adding the definitions from my read to the next update Thanks.
no problem reading or tuning on engine side but any changes on TCM side trans feels like it locks up and stalls engine foward or reverse...any ideas?
stuck in third gear. resetsmafternshut down and restart but comes right back. goes 1,2,3 then stays
Could read all the trans tables in 2016 Jeep Wrangler before we sent the ecu in for modification. Now they are all gone and trans tab is mostly empty once we pulled a read on the ecu when we got it back.
Emailed support
Any planned support for 2005 Grand Cherokee 5.7L Hemi TCM? Or do I use the EGS52? Thanks!
I couldn't get it to work. HPT support even did some beta's for me to work with and they found Dodge has a lock on it. I tried all kinds of things trying to ge it to kick in at a 45mph minimum. No go
If you take your RAM to a dealership with larger tires and complain about it bogging when it kicks in @9mph they will only bump the minimum to 20mph.
If you know something different we missed or new please share.
I have a Corsa Performance exhaust and all though Corsa's are famous for no cabin noise or drone, when it goes into MDS at lower speeds it does have a hum. Not bad but is there and loudest at lower speeds. The MDS really does its best between 40 & 70 MPH anyways so... I would love to have a 45mph minimum.
Good info, never knew that (never messed with it)
what is the email for support? I had a question about why I couldn't change trans settings on a 2012 srt8 300 and if there is going to be a way to change settings on a 2005 ram 1500 mega cab.
