Originally Posted by
Steven@HPTuners
I think you're thinking about the blend wrong. The idea is to achieve the demanded fuel mass in terms of current fuel demand. If you're demanding 8lb/min, and PI/DI Blend is 50%, you're running 4lb/min PI and 4lb/min DI. It does not mean run PI at 50% capacity and DI at 50% capacity. If your PI Capacity is 5lb/min, DI 3lb/min, and your demand is 5lb/min with a blend of 60% DI, you get all 3lb/min DI, and 2lb/min PI. Your DI is at 100% capacity while your PI is only at 40% capacity.
As to SOI/EOI, its * BTDC Power Stroke, so 0 = TDC start of power stroke, 360 = TDC start of intake stroke. This applies to anything ~2012+. Some of the older controllers defined SOI in terms of *ATDC Power Stroke IIRC and had correspondingly different number sets.
