is there anyway can control thermostat open timing?
No.
Thermostat is a mechanical part. You choose what temp thermostat you want to run.
thanks.
i checked thermostat. it works by heat coil, heat coil push wax type.
so i guess ecm control heat coil timing..
thanks..
so with out thermostat open early,, controls fan turn on low temp is not very help for cooling coolant......
stock thermostat. 105'c
top of thermostat has 2 electric wire.
What kind of vehicle is this?
2014 gm chevy cruze 1.6t
Go to Fans > Control by ECT > Desired ECT and lower the temp values. As per the service manual, the stat begins to open at 103C with 0 volts, and 80c with 12 volts.
So looks like the lowest temp settings would be 80C for the Desired ECT table. Then lower the fan temps to suit.
Russ Kemp
