1 Attachment(s)
Idle TPS will not go below 3"
A bit of a strange one. The throttle will not go below 3* when the Throttle Angle Source is in Idle Control but it WILL go to the minimum setting (1*) when the throttle angle source is in Torque Control mode.
Regardless of how low I set the airflow target, and ETC angle for idle, it is stuck at 3* which in turn prevent the car from having an idle below 1000 RPM.
Any insight is greatly appreciated.
This is a 2014 Coyote GT manual with the CobraJet manifold and dual 65mm throttle body.
Attachment 132589
