Originally Posted by
hydrocarbon302
Thanks guys.
The engine signals I'm going to supply to the ford PCM using the ford sensors or signal converters are:
CHT/ECT
MAF
IAT
APPS/TPS
MAP
BARO
CKP
The sensors I'm not sure about are:
Camshaft Position Sensors - There's two on the 5.4.
02 sensors - probably not needed.
COP and fuel injector open circuit detection - Hoping this wont piss off the ford PCM and cause it to do something I don't want it to do.
EVAP, EGR, and other emissions equipment. Again. I'm hoping I can disable these and not cause other problems.
Since my truck has a electronic throttle body (no throttle cable), I have a creative way to use the Fords ETB output to emulate the Dodge APPS signals. If I can disable the ETC error checking and idle control functions I don't see why it wont work. My signal converter takes a 0.8-4.8 PWM signal from the Ford PCM and converts it to a 0.4-2.6V analog signal for APPS2 and a .08-4.8V analog for APPS1 on the Cummins PCM.
