P0106 Map Performance..... HELP - UPDATE!!
Street rod application, New L96 (6.0) all stock engine with a PSI harness. I have done this same engine combo and cold air intake set-up several times before and have never ran into this problem. It keeps setting a P0106, it will do it pretty much every drive cycle and it sets at low speeds, 4-9mph. Runs and drives normal, map and baro readings look normal. So far we checked the map connector, pin location, ecm connector and pin location. I have new parts on the shelf so its easy to swap parts and just try things..... I have changed the MAP, MAF, Cam sensor, Throttle body, none of this made any difference.
Its my understanding this code sets when the map reading doesnt fall into a predetermined value, based on things like air temp, coolant temp, throttle angle, cam position.
I did a search on here and only found a couple similar issues and seen something about being able to "open up" the map readings or chart. Any help would be great, I havent tuned a lot of these things yet so the more instructions the better.
Thanks!
