*New* Line Pressure During Shift (Based on turbine speed) and adaptive CLADP disable
Had eric add this in, awhile back for all 03-16 trucks.
That are available in ford TCM A2Ls with OLS and arent available on previous mainstream available softwares.
This will solve most soft mushy shifts and will firm up shifts abit so be easy on this.
In stock form ford has it set to 150 psi on the top end on oem calibrations for 03-10 5Rs 11-16 are set to 140 PSI.
This is based on turbine speed.
Labeled under "Shifting TV Pressure" *Shifting* 5x1 table
Adaptive disable, basically does what it says. It will disable the TCM based adaptive CLADP logic..
So with it off, it will not pull pressure and "learn".. This is helpful under high HP situations where transmissions constantly "flare" and "revslam" (Targeted torward 03-10) but is helpful on 11-19 6R aswell.
To disable lower RPM to a very low value, also lower temp to a very low value.
This will block CLADP from enabling.
Under Trans > Shift Properties > Adaptive > General
