escalade 2002 6.0HO fuel flex conversion: no FF parameters like avalanche 2002
Hi,
last time I convert my 2002 avalanche 5.3, easy, adding injectors and sensor, and just activate the FFV in the PCM.
now I try to do same with the 2002 escalade 6.0.
but it don't have any fuel flex possibility into the PCM...
I have the biggest injectors, the sensor. also a another pcm from a avalanche 2002 5.3
may be I can do something with all of this?
-the pcm of the 2002 5.3 have a cable trottle and the cadillac is wired.
-ECM are physically same, writed J1 BLUE near the blue plug (called P59)
-VATS will like another PCM/serial?
-can I program the 2002 avalancche OS with flex fuel into the cadillac2002 pcm?
-may be I'm not the first guy to do this, will I found a hpt tune ready to use?
thanks for helping
