Originally Posted by
Jim P
The adder table doesn?t subtract from the main that I have ever seen, it uses the correction table. The correction tables aren?t always used, they are only used under certain conditions. For example on my 2012, the pilot timing correction table uses which ever provides the greatest amount of timing, if at a given ECT and IMT the result of the multiplier and the cells to be used in the correction table are greater than what it would be if it used the same cells in the main table being used it would use the correction table and ignore the main table. I could change the cells to be used in the main table to whatever I want and it won?t make a difference until it exceeds the timing output from the correction table and the multiplier being used, then it would ignore the multiplier and correction table as use the values in the main table being used. If I don?t want it to use the correction table at all I set the multipliers to zero.
