This is the VCM suite info 2.24.1165, should be the latest version.
So after all this, I uninstall VCM Suite and redownload and install and wooohooo, 105kpa 3bar sensor in the MAP 3bar PID.
Check it out, MAP reading good, IAC count much better, and everything else is starting to come together.:yay:
I couldn't tell you, but I hooked up my wife's escalade (running 2bar OS and map) KOEO scanner showed 0kpa, bump starter and 50kpa. I know her truck is right and has always been right since converting, so uninstall, re-install and 0kpa KOEO, Flippin ready to throw all electronics but then one last hope, bump starter and there it is, 105kpa in the 2bar MAP PID! Over to S10 and exact same. Going to wrap everything up tomorrow and start logging and dialing it in. Thank you for all the hours and help you provided.
