2 Attachment(s)
No start issue after rebuild.
I've got a 2002 5.3L engine from a flex fuel Suburban that I put in a '69 c10. I had the engine rebuilt with a BTR stage 2 truck cam. 4L60E trans rebuilt with HD internals and Circle D 2800 stall converter. Attachment 96635 Attachment 96636 Got it all installed and it won't start. I've put a noid light on all injector plugs and get light. Spark tester gets spark on all coils. Fuel pressure is adequate. Vats turned off. Put a new factory replacement intake manifold on. It came complete with new throttle body, injectors and all sensors. The only two sensors on the engine that I haven't replaced are the cam and crank, as the engine ran before I took it out. Only has two O2 sensors, intake uses the truck MAF/IAT sensor, has the flex fuel 33lb injectors with the return style fuel rail. I'm just trying to get it started so I can get it to the dyno tuner. I've attached the tune and scan log while cranking. Any help is greatly appreciated.
