Fusion Sport - WOT shifting keeps hitting 6500 RPM revlimiter
I've been struggling to figure out why the 17 Fusion Sport keeps hitting a 6500 RPM rev limiter in Sport mode. I changed the shift schedule tables as a last resort so that it shifts earlier, but no dice. It seems to only do it in 1st and 2nd gears. On the 2014 SHO, I know if I manually downshifted into 1st, it would not automatically upshift into 2nd. So I need to start from a stop and launch in Sport mode. On the Fusion Sport, it seems to do this in 1st and 2nd gears, but if I'm on the freeway, hit sport mode, and just mash down the throttle, it will downshift into 3rd, and perform a WOT 3-4 upshift.
It's the same 6F55 as the one in the SHO, but HP Tuners is missing a lot of rate limiters/limiters in the Fusion Sport strategy and I never had this much trouble getting the WOT shift points dialed in with the SHO. All I did on the SHO was change the RPMs in the 2 trans shift tables and never had to touch the shift schedules or even turn off Torque Based shift scheduling.
Any ideas?
