Thought i would steal the idea from the ecu repository thread and create a separate thread for the ZF8 TCU
Stock TCU file 2011 a4 8K0927158S__1005
2012 stock A4 8K0927158S__1003
2016 rs7 4g0927158bh_1005
Just an idea based on what I do is label the file with the year, model, engine or trans, and the actual part number as it makes it easier to identify later.
I like the idea. I think it would be worth noting what HW and SW version you have, which I think is what BB-TT has done?
Anybody got Q5 TDI stock pulled by any chance and could share?
Here you go,
anyone got a tuned file for a 2015 SQ5? Looking for something that holds gears and is better than the stock file.
Here's the stock file
sent u a pm do you have an ecu tune? no point in increasing the shift point if the rev limiter kicks in before you shift. Have you logged which TCC patterns are being used in sport and manual? Mine using 3&8, and 27 &47 almost exclusively in sport and manual. i can point u in right direction but am not going to waste time modifying a bunch of maps/shift patterns if your ecu doesn't use them.
Totally appreciate it and yes I've got an APR stg 2 tune. If you can point me in the right direction, I'd be grateful. I don't think we need to worry about the rev limiter kicking in early, due to the tune, so really looking to leave the normal "comfort" as is, but change up the sport/dynamic and manual for sure. TIA
2014 S8 ZF8 Stock 4H1927158EG_1002
Attachment 112848
Stok 2.0 q5 zf8 file 8R0927158E__0009
Attachment 112858
adding a 2016 S8+ stock TCU tune. Some slight differences with the rs7 map but the Max Map showed no differences.
So is it as easy as flashing/writing the s8+ or rs7 tcu file over my existing? I have 16 a8l w/ zf 8hp
Not that easy, you have to edit your maps and just put those values in I believe.
