Checksum error med 9.1 after running
hello, I'm having a problem with my tune, audi a3 tfsi 2.0 2008 manual, I did a tune in this car and it worked perfect without errors and without codes, but after driving just over 100 kilometers the car goes into emergency mode and generates an error of checksum p0601 and it stays like that until I record another tune, then it unlocks and works, I changed a torque monitoring table, is that what is causing it?
What's your file look like? 👀
Quote:
Originally Posted by
BigShack
Hi Fnetotuner, I am also currently having the same issue on my 2008 skoda Octavia mk2 vrs with a med9.1 ecu and ea133 motor seems to happen after around 150km of driving without an ignition cycle it has been an issue since flacing my ecu. I have reverted back to the stock tune didn't fix it, re wrote my map after finding it was missing parameters that the stock tune had. Still no luck also talked to the support line who told me to disable the fault code you get the same issue but without a fault code i feel it may be an issue with the software but need to talk with hp tuners support about the issue its a real pain in the ass as i need to bring a computer and my mates dongle with me when i drive and constantly reflash the car.
Is it possible to see your tune file vs stock file? I had a similar issue and just updated all aircharge conversion tables . I always had epc above 50% engine load . I believe the ecu sees not enough boost the same as too much boost. As weird as it sounds . It may be to prevent high turbine rpm from a boost leak . But idk 🤷🏼*♂️ just a thought .
