4 Attachment(s)
Calculated engine load only 60% WOT
I have installed LE9 injectors for my 2.2 LAP swapped Miata. I was running siemens 60lb injectors before and one went bad, I installed a set of red top 33lb Saab injectors and tuned the car without a wideband mean while I received the LE9 injectors and wideband. After the install of the LE9 injectors I noticed I had a vacuum leak at the MAP sensor and fixed the issue. I am adjusting the MAF table and I notice that the car is not performing like it was before. the fueling is almost decent but I noticed I am only getting half of the power of the motor. after looking over the data logs I realized I am only getting about 60%-67% engine calculated load on WOT. Previously with the vacuum leak, the car was performing as it should and showing the correct amount of calculated engine load. I did not change anything else but the fix the vacuum leak and pull out fuel since it was leaning out with the leak, i did make changes to the PE table but I don't think that would cause this. I could be wrong. any ideas why this would happen? including logs and the tunes for each log. both logs are with the same injectors except one is with vacuum leak and without.
