Is there a guide for changing the settings for temp and duty cycle for pwm fan control? Thanks.
There is no guide, but it's pretty straightforward. Fan settings are under "System". Here's a screenshot from one of my tunes that has worked well.
Attachment 114290
I’ve monitored AC pressure to kinda help with this. I think I started bringing fans in low-speed around 900kPa or something. There was a correlation someone came up with that around that pressure was around about 140* in the engine compartment or something. It’s different for each car but using that method guided me to get the fans to come on in traffic, hold temps well, and have the fans turn off when the car was moving.
I've re-scaled [Desired %] table, made it start 160* until 245*
also, adjust [mechanical thermostat] value and [Desired ECT] table
Thanks. Your chart is kind of what I did. Had to use a fan controller from a Jeep Liberty to work with the old school electric fans. Still get variable fan speed, just not as smoothly.
Thanks for the chart
I'm not having success with System/Fans/Vehicle Speed Adjust - fan % logged seems to ignore it.
Any suggestions, right now I'm stumped?
Attachment 118541Attachment 118542
here's the tune and log
