5 Attachment(s)
3 bar idle issue and no start after writing file have to use stock map to start
I have an issue with a 3 bar OS when you write the file the engine wont stay running. I have to put the stock map sensor in, engine starts runs rough shuts down then i plug in the 3 bar and the engine starts runs stumbles finds itself takes forever to idle on its own. Once closed loop kicks in fuel trims are at 40% so I do the whole VE copy paste thing etc. write the file and same thing I have to do the whole MAP sensor thing again I run the engine and the fuel trims will not lean out in 35-40 kpa range. im down to 2-6 on the VE table. So im doing something wrong any advice will be greatly appreciated. attached are the files. on the scan log labeled 3 bar rich map swap, is where I put the stock map in crank it then swap back to 3 bar map to get engine running, then theres the regular 3 bar no start log and a log where the engine is actually running and showing -40 FT. For the tune files one is where I started and one is where the tune is currently at.
Car Hystory: It was a procharged car running E85 made switche to turbo. currently it has bosch 250 lbs injectors, two feul pumps 60 psi fuel BTR stage 2 CAM,
Right now just tryng to get the car running to take to dyno
