BF ZF6 Speed to TH400 No data logging when trans removed
G'day fellas,
I have got a 2005 bf xr6t that was a factory zf car i have now put a turbo 400 in it and when i have gone to change it from a auto to manual in the trans section of the tune i loose the data logging in the vcm scanner.
When i plug the trans back into the loom and select enable on the trans in the tune everything works as it should
When i unplug the trans but leave it as auto in the tune the data logging works but the car wont rev over 1500rpm.
If i unplug the trans and disable the auto in the tune the car will rev and drive all ok but i have no data logging. I have a O2 sensor wired into the side of the mpvi pro and it will log regardless of what the rest of the car is doing..
Was just wondering if anyone else had come across this issue before and could give me some advise.
Also if anyone has a BF XR6T manual tune I could get a copy of it would be greatly appreciated.
Thanks in advance, Bill
