How To's & General Tuning information
As always we freely welcome any Ford tuning information anyone would like to share to help others along the way. Feel free to post it in this thread to be added, create a new post or pm a moderator to have it added to this sticky.
Thanks in advance,
Bill
Hi Bill,
It seems like not many people have the knowledge of tuning the Ford vihcls due to the fact that is a new car, and it is completely deferent than the GM Cars. So we would like from HP Tuner team to elaborate on how to do basic timing, and fuel tuning for the Ford Mustang 3V.
Regards,
Husam.
Quote:
Originally Posted by MC PERFORMANCE
Hi Bill,
Regards,
Husam.
Won't happen. We create a tool that will allow you to alter the parameters in the pc, we try not to get involved in the "this is what afr this engine should like" or "this is how much timing to add" as this then becomes a liability issue put upon us. Tuning has always & will always necessitate the need for R&D on how to tune & with several tuning classes offered theres always someplace to learn how to tune.
-Bill
Bill,
I think you got me wrong here. I meant explaining how to use your software to tune the Ford. For Example, I would like to know what to play with to control WOT timing. It took me a while to figure out the fuel control but can't find which map in the software controls the WOT Timing. I hope you understand what i am trying to say now. I read the help file on the software and it was helpful but not very.
Husam.
the borderline knock table is the main spark table from my understanding.
Bill,
Husam.
Husam,
The Ford 150s have quite a number of parameters available for tuning. While I am new to the HP Tuners, I have been using SCT's Pro Racer software for 2 years now. A quick comparison shows the parameters available are nearly identical between the tuning software offerings. I doubt seriously anyone is going to provide you with a full explanation of the 100 or so parameters available for tuning these trucks.
Yes the Borderline Knock is a place to start; however, we have quite a number of factors contributing to the final spark advance in these trucks. You simply need to do the R&D Bill spoke of. The most efficient way I found was to start by data logging. Then, compare the results to the stock settings. Look at settings from the IMRC Spark table, the Variable CAM table, the borderline knock table, and of course, MBT spark. Other tables contribute as well. I have heard of some tuners turning off spark adders in all of the contributing tables and relying on only the Borderline Knock and the MBT Spark table. I have never done this as I have been tuning specifically for alcohol across the full range of the engine. It is not too difficult to do the math and determine which tables are contributing. Do be careful when advancing spark. These trucks also have parameters for detecting knock and will retard spark when the knock exceeds the sensor parameters. That is, of course, if you are tuning for gasoline. If you are tuning for Ethanol, you won't have to worry about knock. You still have to get this right; though, as it makes no sense to advance spark beyond that necessary to achieve maximum performance.
Hope this helps.
The best tip I have recieved...
Disable the P0605, P0606 and P1000 Codes.
Here's a really nice write up to get your head around Ford tuning... it is based of SCT's software but reading over it, its very similar to the HPTs software as well...
http://www.contour.org/ceg-vb/showthread.php?t=10724
I am new to using HPTuners, have used it to tune a supercharged H3 and a LS2 with a blower in a pickup and was very happy but I have looked at 2 dfferent fords and the edditor looks like it will work good but I was unable to view a lot of pids that are available with my other tuning software and are needed IE fuel pump duty cycle and injector pulse width, there were a lot more but those 2 come to mind. Did I do something wrong or are there not many pids that work yet ?
Garry
Wasn't clear that the problem is viewing pids with the scanner, it doesnt support a lot of the pids that I can view with my other tuning software. Am I doing something wrong or can we get more ??
Quote:
Originally Posted by Trailblazin'
Nice Find!!!!!!
I've been looking for a doorway to the "Darkside":secret:
Bill, if you could throw this in your 1st post above:
http://www.hptuners.com/forum/showthread.php?t=20810
RWTD
done
zq8bob
Can you explain the reasoning behind disabling these?
sweet we got Maf Volts in the scanner now :D time for some Lambda error histrograms soon.. just wish the frame rate would increase a little and i'd say the ford scanner is complete!
looking for help to set up the fuel side of things for id 1000 injectors
any help please
When you say alcohol are you referring to E85? Only because I have been looking for software to tune my 2008 5.4 King Ranch with E85. It burns very clean (no black exhaust tips).
AWEBB
Yes
