Logging wideband via serial port adapter
I am trying without much success to log wideband data through a serial port adapter.
Windows 10 on a Dell Inspiron laptop
HP Tuners / VCM Scanner 4.0.12
AEM 30-0310 wideband controller
USB-Serial adapter (labeled FTDI FT232RL on the female serial plug)
Male-male serial cable cut in half
AEM's instructions say to connect pin 2 to the blue wire from the wideband controller and pin 5 to ground.
I used a continuity tester to map the wire colors to the pins on the male serial cable. Pin 2 is yellow and pin 5 is brown on my cable.
These are the cables I have:
The cables (USB-Serial adapter in the middle / Half of a male-male serial plug on the outside):
https://i.ibb.co/sJ7z76f/Cables.jpg
USB-Serial adapter:
https://i.ibb.co/CWvhw8H/Serial-Adapter.jpg
Half of a male-male serial cable:
https://i.ibb.co/nnq7tbg/Serial-Cable.jpg
The computer is seeing the USB-Serial adapter and the settings for COM port match those specified by AEM's manual:
https://i.ibb.co/0f3ys52/USB-Serial-Port.png
In VCM scanner, I added a channel for a serial input. There is a pre-defined one for AEM - AFR, which I chose. When I go to log the car, the channel disappears from the list. From searching, I understand that means the channel isn't reading correctly. I tried right clicking on the channel and using transform to specify the model of wideband controller. There is a preset for AEM 30-(30x0, 2340, 5130), but that doesn't seem to change anything.
I'm stumped on why it's not working.
