Is there any capabilities of swapping the map sensors to a 2 bar on the Gen 2 ECU, I see the settings for the Map but my issues is the axis maxes out at 105 kpa for fuel and ignition and won't allow you to edit the axis to any higher number. Is there a solution with the Gen 2 ECU for that or is that a factory ECU limitation? Thanks in advance for any help!
