1 Attachment(s)
E80A help and clarification
Hello,
I am having a hard time understanding this PCM. I would like to tune VVE tables only and leave the car non-MAF. The stock tune appears to have MAF dis-abled with high RPM's, am I reading that correctly? I assume to keep the car in VVE only, I would need to change the MAF htz, and remove the PID from logging?
My plan was to start with part throttle up to around 4k RPMs dialing in fuel trims before starting on WOT fuel trims. After Im finished dialing in both, what all should I re activate in my tune?
Turn COT back on, PE, piston protection??
Any help on what I should turn off to start VVE fuel trim tuning, and what I should turn back on after Im done would be greatly appreciated. Seems to be little information on this PCM that I can find. Thank you for taking the time to read :)
