Originally Posted by
Lakegoat
Several things---First go to Engine--Spark--Base idle and make your chart look like the one I attached. Go to Idle adaptive spark--Overspeed and make all the numbers -5 from 64rpm up. Underspeed---make all the numbers 8 from 64rpm up. Go to Torque mgt --General and open ETC limits. Make the first row across all 0's, all other numbers on the chart make 100.
Are these the stock injectors?
Go to Fuel--Power Enrichment and change Delay to 0. Ramp in to 2.00. Go to Temperature Control and COT--Disable. IAT spark will need to be changed but later.
You should be idling around 17-19 degrees after this. If not, you have too much Base Running Airflow.
Be sure and make a copy of the file before you make changes.
Log Cylinder Airmass in Channels, also injector duty, Injector tip temp, -------where is your Wideband Input? I don't see it. You can tune the low rpm stuff with STFT's (Turn off LTFT's) Just don't WOT because boom.
