I was wondering if anyone has used the PLX widebands? Also wondering if HP tuners Pro will work with it?
Yes & Yes
Were in the process of using one now, and i currently own the Innovate Motorsports LC1 with luck with HP Tuners also.
I have the PLX on mine works great no issues...John
Mine works good as far as I know.
how do you set it to display on the gauge and also datalog? Or maybe a better way to ask is where do you take your output for hptuners from if your using the 4pin connector for the guage?
This answer your question?
I did find that all I needed hooked up was the wire to #1. I disconnected the 2nd wire (ground) and got the same readings with it hooked us as it did when disconnected.
http://www.hptuners.com/forum/showthread.php?t=11192
according to this picture that would be for narrowband
http://www.hptuners.com/forum/attach...6&d=1175327143
