Controller Unlocker: X36 Exceed Number of Attempts
Vehicle Info: 2000 Camaro, 5.7 L, 8 Cyl, GM_P01
Hardware: P01 ECM, Gen3 V8, 4.3L V6
OS: 9381344
PCM HDW: 16220610
Serv # 09354896
Hopefully the information above is enough. The first set of info is displayed in VCM Editor when reading vehicle. The other set of numbers is on the PCM itself. I have the new MPVI2 Pro Version. The the x36 error, as stated in the title of this thread, appears after it tries to communicate and read entire.
The engine is a 5.7 LS1 from a Camaro.
I have read that this error most likely means the PCM is tuned and needs to be reflashed or purchase a new one. This came out of a stock Camaro, I did heads and cam to the engine.
My question is, is this the correct PCM for this vehicle? Noticing the v6 in the hardware info, was a v8 calibration/os flashed into a v6 PCM? Also, is it truly tune locked or can this error mean other things?
