1 Attachment(s)
6L80e TU/TD: Downshifting twice for a single signal
Before I get too deep into troubleshooting I want to see if someone has experience with this problem.
I have hardwired the TU/TD signal to my 6L80e and it worked well for a few months (following the wiring info on this site). I have been adjusting shift points to improve shift feel (along with CT downshift elements) and noticed that in TU/TD mode it will downshift twice when pressed only once.
I can move to manual mode and it stays in the gear just fine. I can also upshift and it goes up one gear. When I signal the downshift it shifts down a gear and then almost immediately shifts down again. My first thought is that the switch is faulty but this behavior aligns with other transmission tune changes I've made so I suspect I inadvertently changed something.
Tune attached.
Thanks!
