I just updated to 3.2 Scanner and im trying to add my wideband to my scanner and I cant figure it out. Will someone please walk me through how to add my wideband so I can scan properly. I have a PLX wideband and have a Hptuner Pro.
Top of this Scanner sub-forum is a sticky with graphics and video How To's.....http://www.hptuners.com/forum/showth...tarted-Threads
Here is the Wideband Video link...Subscribe and Like please....
https://www.youtube.com/watch?v=3TQdrTMnljI
You can either leave as pre-configured or contimue to establish a user defined where you will be able to tweak the offset value to compensate for variances due to ground/analog offset issues. Also you can select AFR or Lambda, which I recommend.
Ed M
Short version is add the MPVI input to your list of channels, right click, transform, find the WB and units you're using (I'd recommend lambda) and apply the transform.
To use the WB data in a chart/graph you'll want to search for "PLX" when adding a parameter, NOT the MPVI pro input #
Hi, i have the Zt-3 wideband setup and using hptuners vcm scanner i can get a reading but it doesn't change even though the dial is changing all the time. It's reading afr as is the channel in the scanner. What is wrong do you think?
Cheers
