Are Hellcat fuel trims fat by default?
So I was going through some logs today and I noticed on my stock Hellcat the the fuel trims are kind of fat. Is this to make sure nothing goes boom or is it required to ensure max power? So some starter knowledge that I learned during looking at the logs and trying to walk it back. Stoichiometric for the cars is 13.85. I found this value bye doing 1/FAR. FAR in this car stock is 0.0722. The next thing I learned is that the Command EQ Value directly correlates to aircharge or pressure ratio. I don't know the inner workings but I'm assuming this is accelerator pedal commanded or throttle position where the tables switch over or perhaps a blend of both. So as an example I found the following values in the log:
RPM: 4803
Aircharge: 1.40
Pressure Ratio: 1.72
EQ Ratio Commanded: 0.76
FA Enrichment: 0.0227
0.0722 + 0.0227 = 0.0949
1/0.0949 = 10.53 AFR
10.53/13.85 = 0.7602....
So the math checks out! Glad I figured out how to work back the numbers, however I am trying to figure out why the default fuel trims are fat. Is this from the factory that way? Is this to make the car happy? Is it required? I know I plan on making the two tables FA Power Enrich PRatio Based and FA Power Enrich PRatio Based the same and shooting for 11.50 as the number in both tables but is there anything to be gained from this? Will the car perform better instead of washing the cylinders with gasoline?
