Does anyone know how to remove the 120mph speed limiter on this vehicle? I tried raising the Limit By Airflow and Limit y Ambient with no luck as it still has the 120mph normal stock speed limiter.
Thanks!
Attachment 90448
Thanks!
Attachment 90448
go to speedo and change it there under limiters
That has been raised significantly and it still limits to 120.
can you post screenshots of your changes to the speed limiter?
that should do it. have you tried logging to see if you are hitting any other limiters?
