1 Attachment(s)
Weird WOT flex fuel issue. Transient issue maybe? Please help
Ok so I got all of the main parameters changed and set for the ethanol sensor to work and all of that is working well.. the issue I'm having is when I go WOT, if I roll on to the gas everything seems fine and actual lambda follows commanded just as it should. When I do more of a stomp to WOT, actual vs commanded goes opposite. commanded goes to .79ish and actual shoots up to 1.22ish lambda. There are some blend tables in the transient tab that were all 0s and I populated them with ones I found from a Holden file. Maybe that's the issue? The truck 6.2 file doesn't seem to have those tables but I do have the flex timing table from the truck file
I have some screenshots of the tables I think are causing this problem and another one of the problem happening in a log.
I can upload my tune and full log in a few hours.
You can see on the log pic that the first time I go WOT it goes lean but then when I roll on the throttle right after, it seems to work just fine.
I usually just end up figuring this stuff out, but I'm really stumped on this one.
Car is a 2011 Camaro ls3 N/A basic boltons
Attachment 90542
